MetalMan
MetalMan's Avatar
11.12.2006, 10:25 PM
Running such large tires through the built-in BEC with 12 cells will put quite a strain on the built-in BEC. This causes the BEC to get HOT, and once it gets hot enough, it will cause the Mamba Max to shut down. You can help this problem by running either a receiver pack or a UBEC.
