11.14.2006, 12:55 PM
the same way you brake now, With the mechanical brake. you need to use a Y adapter to split the throttle channel
You can also look for a way to fix the one way bearing to the shaft, or lock the 2 speed crown to the gear. (with the fixed gears, you won't have got a 2 speed anymore)
