rchippie
rchippie's Avatar
11.15.2006, 07:04 PM
Originally Posted by BrianG
While you're at it, shorten the wires if possible. They are kinda long considering they are only 14GA.
Actually, I think I remember reading in the manual that it was perfectly acceptable to do so...
Brian i already planed on cutting them as short as possible. The wires on mine are 13g not 14g. I also plan on using deans plugs on the batterys. If i decide to run 14 cells instead of LIPO's, i assume i can make a jumper of the speedo so i can use two packs , like you would do on a BK warrior ?.
REAL MEN RUN BRUSHLESS
