11.16.2006, 12:33 AM
Added Mugen diff and temperature converter (sorry I forgot about the diff Dafni).
CHC: So, you think a 1950 has the same torque as an XL motor of the same kv? I figured an XL was closer to a 1940. What I ended up doing is made a list of 4 motor sizes (S, L, XL, and XXL) for each motor can size (eg: 540) and equated each level with a vehicle weight range. Then, each motor falls into one of these levels so the program knows which motor(s) to choose based on weight. It seems to be pretty accurate judging by the common setups found here.
