glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.18.2006, 04:40 PM
2s is great in a a 4wd with a high rpm motor like the 7700... that's what I have in my xx4 and it's impressive. I can almost hear the belts stretching :)
All you need to do to make the packs is parallel together the small packs.
Take four of them and shrink/tape them together into a brick, and join all for of the + wires together and the - wires together. Do that again with four more of the small packs.
Now you can take these two bricks (each are now 2s4p) and either wire them as a saddle pack, either in series for a 4s4p 3200mah pack, or in parallel as a 2s8p 6400mah pack.
I would do the 2s myself... and you might not need to make it that big. You could do a 6p instead if you want a smaller lighter pack.
