glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.18.2006, 10:06 PM
Originally Posted by sleebus.jones
Well, it seems to defy the laws of physics at first glance. The amp draw goes up as the battery voltage goes up...that doesn't make sense. All things being equal, higher voltage should equal less amp draw.
Actually this is not true at all... their numbers are correct.
Amp draw increases with voltage. Given the same motor, etc... more voltage always means more current.
The high voltage/low amp draw thing is due to using a different motor/gearing setup with the change in voltage.
This is how a system can operate on lower amp draw and still make the same power (watts). You use a much milder amp draw motor and just feed it more volts.
