11.18.2006, 11:27 PM
Alot of this is over my head, but for instance, the XL motors are all rated for around 1800 watts (I think), so if the dimensions, etc of the motor stays the same, but the wind/RPM's change, the watts is gonna be a constant. Example:
1800W / 22.2V = 81A
1800W / 14.4 = 125A
But what if the KV changed? The watts would be the same, but wouldn't the amperage change alot with the KV? Yes, it would. A higher wind XL motor (like a 9XL) on 18 cells will pull less amps than a 7XL on the same amount of cells, will it not?
Basically I see it like this. The formula you gave would work if the RPM's were a constant between each motor. That formula might work for other things without the extra variable...Now this may be wrong...But this is the way I understand it.
