sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
11.18.2006, 11:35 PM
Squee, you've got it spot on. Motors are designed to do a specific amount of work. It's just like a horse, no matter how hard you whip it, once it's going as hard as it can, it's not going to work any harder. If you need more work done, you either need:
1. A different horse
or
2. More horses!
Yes, if the KV changes, you've changed "horses" and the draw will be different for the same work done. It's not as over your head as you think! :)
Artur: When you apply more volts, you get more RPM, up to the limit of the work the motor is able to do. It's the same analogy with the horse, you'll only get so much out of the motor, regardless of what you do.
Sleeb
