starscream
RC-Monster TQ
starscream's Avatar
11.19.2006, 09:32 PM
The problem I see star scream. You probably couldn't run the motor at a wide open or as much throttle as you did with 5s as you did with 6s.
By adding the extra cell. You accually added more current to be drawn.
If each cell is capable of making or running 1000 watts a piece of run time.
Then you have 5000 with 5s and 6000 with 6s. Just an example.
My testing area is only so big so I can only drive the truck at a certain max speed without losing control. The test runs are as consistant as I can make them. The advantage of 6S is the truck reaches the max speed faster than with 5S. With that said, it seems that I am at WOT more on 5S than with 6S so maybe that is playing into this discrepancy in runtime :030:
None the less, the discrepency is there so it seems to be an advantage in a racing scenerio.
Ha Ha
