crazyjr
crazyjr's Avatar
11.20.2006, 02:38 PM
The problem I see star scream. You probably couldn't run the motor at a wide open or as much throttle as you did with 5s as you did with 6s.
By adding the extra cell. You accually added more current to be drawn.
If each cell is capable of making or running 1000 watts a piece of run time.
Then you have 5000 with 5s and 6000 with 6s. Just an example.
I believe you are wrong there, if it was parallel you would add amp capacity, not in series. In series you add voltage and not amp capacity, but the wattage would still go up like you were saying, just not on amps but voltage
