Thread: A question
GorillaMaxx360
GorillaMaxx360's Avatar
11.22.2006, 06:55 PM
Originally Posted by GorillaMaxx360
Were(maby tell me or show link thanks) and how much are the 40mm fans that work with the cnc machined esc cooling heat sink.[URL="http://www.rc-monster.com/proddetail.php?prod=RCM008"]also this fan that you direct me to or recommend to get, does it have low enough voltage to not make a noticable difference in run times. Also if it is three pronged i just use a y joint right! but if it is not 3 prong (like servo useualy uses) how do i make it 3 prong or is there a better way to wire it. Also a pic who has this setup. It would be nice to se
