rchippie
rchippie's Avatar
11.24.2006, 02:36 PM
Originally Posted by Serum
Yeah, i understand what you mean..
If you just make it hot enough, it would be a good connection, but you need to pay close attention on the other side of the circuitboard, to see if the tin is melting on that side too..
While you are at it, you might as well put the output of the UBEC directly on escs receiver wire I was planning on doing that with my mamba-maxx. What bec did you get? i got one with a very small footprint, which would blend right in..
Rene i got the one mike sells, the UBEC. What is the benifit of putting the ubec output wires directly to th ESC reciver wire versus plugging it into the reciver ?.
REAL MEN RUN BRUSHLESS
