Originally Posted by VWT4
I don't understand you.
Adding a gasket between the halves won't change the width of the case, only the length will increase.
BTW .05mm metal to metal conntact didn't let me fit the case.
Hi !
I know what you mean, i tried to install the gear box this night and no, it does not fit.
I am going to buy a milling cutter for my dremel today and cut out the
missing 0,5mm from the braces.
That will not hurt the stability...
Marc.
