marc993turbo
11.25.2006, 05:49 AM
Originally Posted by Serum
that .05mm can't hurt that bad..
You can use a gasket between the two halves, i know Ryan used it for his.
Hi !
I think you are refering to the transmission half cases that donīt fit quite well because they are too short.
You can either use a gasket or dremel a little bit on the input shaft...
I did the second.
Marc.
