Thread: Quark on 6s
jhautz
jhautz's Avatar
11.26.2006, 03:52 AM
I talked to Frank at Quark just last week while I was checking on a repair I had sent in to them. I was asking about the ''new'' 125s that are showing up with the colored wires. He said that everything else except the wire color is identical to the white wired versions. Only reason that they have new wire colors is that some complained about not having different color wires so they switched to the colors vs all white. Nothing else changed. He also said next batch will have some more conventional colored wires on them, rather than the neon.
I also asked about the 6s issues and the heat issues and he acknowledged that there was room for improvement in both areas, but wouldn't call it a problem. They will support anyone having issues with getting there setup working properly.
I asked if they were going to''fix'' these problems and he said that they were not planning on making any revisions to this ESC. Instead he told me that they are planning a NEW CONTROLLER that is better designed for the 1/8 and MT applications. Reconfiguring, fixing the 6s issue and moving the heat sinks to the top like a more conventional ESC. All he could say was maybe next year as a time for the new esc.
Anyway, I thought that was some interesting news. He couldn't/woudn't give me any more info than that. As you might suspect I started asking alot of questions about this future ESC.
... I guess my point is, the 6s issue is no different with the neon wire versions vs the white wire versions.
to make it...
or break it...
Silent...But Deadly
