Thread: Quark on 6s
11.27.2006, 12:42 PM
I've had this happen to my "old" white wire version. You program it to a certain drag brake level, then exit. Then if you go back in, it is still at the default setting. Is that right?
Well, actually try it once you exit. I've found that even though the programming seems to revert, it actually doesn't. I programmed the DB to, say, 50%, then exited. I then ran it and it was definitely set to 50%. When I got back in the programming, it seemed to be set to the default value (3%?).
So, to make sure everything is where I want it, I go through all the options and set each one to what I want just to be sure the settings are holding.
At least that's how it seems to work on mine...
