11.28.2006, 03:22 PM
I ran mine with the stock case with no problems. One problem with using longer screws though is that the one side of the case has limited room for nuts on the other side. The other side is fine to put nuts on, which I did and never had a problem. The four holes should be enough to do the job fine unless your threads are already trashed.
