Originally Posted by zeropointbug
I wonder if lapping/sanding the bottom of the Quark with 600 fine sand paper and using Arctic Silver and pressing it to a thick aluminum upper chassis brace that would take all heat away.
I would get the heat sink and not sand the bottom of the Quark. Then use the arctic silver to attatch the heatsink.:027:
you could however drill holes in the heat sink as well. I think this is what Mike did to his.
