BP-Revo
BMW M Power!
BP-Revo's Avatar
11.29.2006, 01:09 AM
I would recommend a Hyperion EOS7i with the Hyperion Balancer. I have been looking into lipo for quite some time, and the setup (if I choose to go lipo) I plan to get is that charger setup with the 8000mah 2s2p Lipo's.
If you have a radio with channel mixing, set it up so that the servo only moves when you apply brakes and the ESC only receives signal under throttle. This will make it a little easier to setup.
If not, go and program the ESC to have no brakes and reverse (I'm quite sure its possible) so that way the ESC just gives throttle and nothing else. This will save the ESC alot of work and save battery energy and reduce temperatures.
