Thread: Max voltage
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.29.2006, 01:31 PM
Well, ya it's both the max RPM and amperage capability/heat.
Once you go over the typical voltage for a given motor/Kv the efficiency goes down drastically, and you will run into heat issues.
A motor likes to have a voltage just before this occurs, it's usually at its peak efficiency. 'Usually'
