MetalMan
MetalMan's Avatar
11.30.2006, 10:07 AM
Originally Posted by t-maxxracer32
oo so pretty much the 7700 is like lets say 40 mph witha 2s 6000 mah lipo where as a 4600 can go 40 buit you need a 4s 6000 mah lipo?
That's the right idea, although the numbers are a bit off.
wha would happen if i got the 4600 with a 2s battery? what speeds can i expect? or what speeds will there be with the m1 cells?
thanks alot metalman
Castle says 30-35 with 2s Lipo on the 4600. For the same number of M1 cells, the speed will be slightly less, due to the voltage difference between them and LiPos.
