zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.01.2006, 09:42 PM
k, well im just going to run it for now with a good HS of my own design, or i'll just integrate the HS into the upper chassis, to reduce weight, and i'm sure it would work even better than a separate HS.
Then, if i ever want to do the Alumina mod later down the road... and perhaps I might even mount liquid cooling blocks to each side of the FET's for extreme cooling, and then run the liquid along the aluminum chassis to cool it... PRETTY COOL
Cheers
