True,
But they can extend batteries life and help ESC.
Is it worth the added weight?
Artur
What do they weight then? I think it would be wiser to gain more cells (with the same weight) and choose a lower KV motor, to simple unload the controller/motor/leads from the high current and gain real runtime instead. (total available joule)
@zero;
i don't know what you think of this, or if you knew it at all; but a flighpower pack delivers 7V under a 100A load for their 2S 4900 mAh pack.. I don't think a more consistent cell is available at this time.. only dropping .4-.5V under a 700 watt load.
