12.03.2006, 10:09 PM
You learn somthing new every day :) I was just wondering since in the warrior there is a red [tab]. I guess that disables the current going to the red wire instead of completely taking it off? Oh well, ill just probably snip the read wire in front of the connector and be done with it. Thanks again. Hoping this truggy is better than the revo - handling wise, hoping its as good in durability. **Edit: Do you think it will run cool enough to not need a fan? If it needs one that not a problem, but thought it would need a little extra cooling since its past its limits.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
