Thread: MM or 125B?
Cartwheels
12.03.2006, 11:11 PM
In case you didn't know, you can pull the red wire out of the plug by lifting the little tab on the plug that holds the little metal connector in place. Hard to explain, but it is very easy to pull out. Then just fold it up and tape it off. That way if you every need it in the future it is easy to get back. If you snip it then it's harder to get back.
