crazyjr
crazyjr's Avatar
12.04.2006, 07:54 PM
I'm running a 9XL on 12 cells NIMH 4400 max amps batteries and have no problems with it running, only rolling backwards and stabbing foreward causes a cog. I would've figured that a 9XL in an undervolt environment (according to others here) would cause a high current problem. I got some 2s 8000 mah lipo's coming and may can make something happen with those
Edit: Just a thought, How many of you with the Neu motors are running the 1/2 winds? I know there is a update coming to allow you to use the Novak and other 1/2 winds wothout problems. Just a thought
