Thread: Can I Win!!
GorillaMaxx360
GorillaMaxx360's Avatar
12.04.2006, 10:46 PM
Alright i think i have the solution to my problem tell me if it sounds good I will go with the maximizer diff cups(standard gear ratio 2.84), slipperential, feigao 540c 7XL, quark 125B, heatsink and, (2) 2 cell orion 4800(7.4v) batteries, a 20t carbon steel 5mm bore pinion, a revo 36t slipper. With this i can speeds of the mid to upper 40s for bashing and by the swap of a pinion get speeds in the lower to mid thirties for racing. and in the end i get the lower cg of the slipperential, the improvement of racing ability form the slipperential, but yet by changing the pinion i can get the speed i want for bashing. I also can get maximizer diffs which should hold up to anything. Is all of this true and should it work if so it sounds like a solution dont you think.
