12.06.2006, 10:51 PM
Why don't you simply get an external LVC for the 9920 since it works ok?
The BEC in just about all ESCs I can think of use a linear regulator and will heat up with high cell counts, so I'd use a UBEC no matter what you use.
IIRC, the BK software doesn't work in WindowsXP if that's what you're running. I'm not sure though...
