Thread: Cheap radar
riceman
RC-Monster Gold
riceman's Avatar
12.08.2006, 02:30 AM
Originally Posted by BrianG
I was just going to strap it to the truck facing down at an angle and see what I could get out of it....I know it works off the Doppler-effect, but wasn't sure how finnicky it would be about the angle and such. Maybe this idea would work better with an optical pick-up instead - like how an optical mouse works...
So, based on your experience, will this work? This would really be something to mess around with - I'd rather not spend the cash on a worthless venture...
As I mentioned - I didn't think the mod would have been worth it. I'm pretty sure the beam orientation won't allow you to get any type of reading with it facing the ground.
You could also get one of these. Set it up in your RC car and let it go the 60 feet 6 inches (distance from pitiching rubber to home plate) and let 'er rip. The only problem I found with this is that the vehicle must come to a abrupt stop as if it were hitting a glove. I guess you could try it... once:005:
