zeropointbug
Z-Pinch racer
zeropointbug's Avatar
Exclamation 12.08.2006, 02:56 AM
OOps
OOPs
I must be really tired, i don't know how those measurments got in there. :025:
The wide chassis is 190mm wide, and the narrow version is 115mm wide.
I just noticed that the body (crowd pleazer is only 160mm, so 115mm version it is... it does give protection against rocks thrown at Quark esc. (will have massive heatsink)
Also, what kind of front-rear balance should i be considering? The motor is closer to the front (15mm forward), so should i mount the batts slightly back a bit?
