12.09.2006, 07:05 PM
I have that speedo... it's pretty good I think... and the motor looks like a Feigao 8L. It should be ok, but I would recomend a lower kv motor... more like 2400kv range.
rcmonster.com has the BK9920 for $150
For $220-230 you could get that and a 9L or 10L motor. I think most would recomend that over the hobbypeople combo.
The mtroniks does have the 1/8" as opposed to the normal 5mm shafts. You can decide if that's good or bad...
