jhautz
jhautz's Avatar
12.10.2006, 06:05 AM
Serum, this is probably the 10th time you have asked me that and I can finally say......
Yes, I do have data from eagletree on these cells.:018:
Just got the eagletree a few weeks ago. The data is obviously not from this model, but I did run this pack in another 1/8 buggy I have.
It was set up w/ a Quark125 a Lehner 1940/7 and this 5s pack geared to 16/46.
I was pulling 130amps (over 30C on these 4350mah packs.) The voltage dropped, but it handled it no problem. I didnt hook up the eagle tree until the very end of the pack (you can tell by the resting voltage being just barly over 18.5) so I'm not sure how valid this data is, and it was also only 40 degrees F outside so the cold weather didn't help the lipo packs.
Here is the data.
This is the only pack I have tested so far. Not sure what I should expect from them under these conditions. They seemed to perform pretty well to me under the conditions.
to make it...
or break it...
Silent...But Deadly
