Thread: Heat?!?
crazyjr
crazyjr's Avatar
12.10.2006, 07:51 PM
Originally Posted by rchippie
I just ran my MBX5 with the MM for the first time today. The motor is a 7xl with 14 cells. The gearing is a 46t spur with a 13t pinion, the temps were 95- 100 for the motor the speedo got a bit hotter around 180 +, with out a fan. Is this a good gear or should i change the pinion & add a fan ?.
Glad to see you got it going
