Thread: Heat?!?
MetalMan
MetalMan's Avatar
12.10.2006, 08:27 PM
Originally Posted by rchippie
What is the normal operaiting temp range for the ESC ?.
I think the thermal protection kicks in at 200-220 deg. F, so pretty much anything below that is okay. However, it will operate better when cooler, as the resistance of the FETs increases as the temp. increases (decreases performance). Also, heat generally is not good for these components when it can be helped.
