12.11.2006, 11:02 PM
Ok, A few changes would be good. I would go with the 3.3 aluminum knuckles like you said, but I would choose the RD Racing knuckes and the 23mm 8mm axle kit. Second, with that setup, you have to run 3.3 sliders, which I would do anyway to be easier on the drivetrain. You don't really have to worry about the durability of them. As for the slipperential, I don't think wheelies should be a concern. First off, the center diff alone should eliminate them, then on top of that you have a slipper, so I wouldn't worry. I would start with 10K fluid and work your way from there. The only thing I dislike about your setup is the F/R diffs can't be tuned with silicon fluid...I would like to think you can use the Revo aluminum cups instead of the Maximixers (maybe Maximizer makes them for the Revo? not sure) so you can use diff oil...I'm not sure about the diffs though...
