05.30.2005, 09:29 AM
You straps are g3. Some of the earlier ones actually had more strength to resist ripping, but the velcro adhesion was not very strong. The g3 straps have prettys strong velcro. Here is a suggestion to try. You mentioned that you run 6 cells flat with an additional battery on top, right? Try tucking the velcro into the slit in the lower chassis plate opposite the humped battery before you cinch it down(run velcro down through a battery cut out and up through the slit in the chassis). This should give you some extra pressure on the batteries. I would double up if it were me
(I already mentioned this).
