12.12.2006, 06:35 PM
Are you putting all your batteries on one side or do you plan to have one on each side?
If you are putting the pack on one side, I'd personally go with a single 5s pack. You won't need a Y adaptor which means less connections and wiring. Really, the only advantage to seperate packs is you have more mounting options...
