Thread: 5s lipo
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.13.2006, 12:41 AM
Yes, i would think the max cycles you could put through them before you should forget about putting more cells in the pack is probably 50 cycles. But, really you don't want to do it. Just do the research about a good setup, and stick with it.
You could over-discharge one cell in the pack, the voltage of the pack may be the 'cut-off' value, but 5 of cells would be above cut-off, and the one cell that was added would be below cut-off, and i don't even have to tell you what happens next.
