12.13.2006, 03:31 AM
I have a 12 volt fan, maybe Ill take your guys advice. Should tap into the Li-saver or have a seperate set of deans and wires to go between the Li-Saver and batterys?
Is there any advantage in parallel vs series when total voltage is the same? Is there more resistance when wired in series? More heat?
