05.30.2005, 01:05 PM
I run 7cells, 6 cells flat and 1 cell hump at one end on top - although soon I will be running with all 7 flat.
I will try lacing the straps and maybe some longer screws.
Just to make sure, to lace, after the last cell I put the strap through the hole the cell sits on then back up through the thin slit at the end, then fastend by the screw?
Thanks alot for the information so far, this is brilliant support.
