12.13.2006, 12:06 PM
I thought about contacting you with that. that would be cool :027:
There are also a bunch of guys doing LST2 conversions. I have all the ratios already memorized so I don't need them in the calculator pull downs. I do point a few of the guys on the LST forums to your calculator. If you think it worthwhile to add I can try to get exact tooth count on each of the gearing combos. The sad part is a lot of the guys on the LST forums are doing the Fine Design conversions and have no idea what the motor rating is.
