Thread: Gorilla Straps
gorillamaxx
gorillamaxx's Avatar
05.30.2005, 04:26 PM
Nick - Since the G1 chassis only had 7 cell slot, if you run all 7 flat you wont need to lace the strap.
If you run the 6+1 hump back try the following - Attach the small buckle strap at the rear (using the bonded washer). Attach the long strap at the front (using the bonded washer) - set the hump pack towards the back of the chassis plate with the hump cell also at the back - this will leave the first cell slot open at the front. Now take the long strap and drop the end into the narrow slot next to the mount - then bring it up through the first battery slot (the open one) and then lace it into the buckle. This will lower the tension point and create a stronger hold.
Try it.
