neweuser
neweuser's Avatar
12.15.2006, 06:22 PM
Originally Posted by mtucker
Is it OK to use the Li-Saver with a car that is using reverse?
I ran into a problem with another brand of Li-Po cutoff device. Most are made for airplanes so when they do their "pulsing" they pulse down to near 0% throttle. 0% throttle on a car controller is full brake or full reverse if reverse is engaged. After coming to a complete stop it then went to full speed reverse. I really should have known better, but I guess the excitement of a new toy got to me.
Seeing a 8 pound buggy flying backwards down your driveway and into the iceplant at near 40MPH is quite alarming :026:
Perhaps the Li-Saver doesn't pulse below mid throttle (neutral for cars)?
Just thought I would bring this up.
Matt
the one that Mike sells will work good for you.
