12.16.2006, 03:58 PM
You just tried each of the white wires? I'm not following what this means. Each motor wire hooks to each of the three ESC wires.
If the motor is hooked up correctly, something is wrong then. The motor itself makes beeping noises when you program the ESC. If there aren't any beeping noises, then either the ESC isn't working or the motor is bad.
Did the ESC lights turn on while you were programming. Just trying to see if the BEC fried (the BEC also provided power to the internal ESC low power circuits).
