12.18.2006, 09:14 AM
I'm a pretty big fan of RPM, so I'd suggest going with RPM shocktowers. I'm not so sure about getting aluminum body mounts either. Even with my emaxx in stock trim, I manage to flip it on its back a lot, which bungs up the body mount posts quite a bit. I can see how one flip would really mess up an aluminum set. With plastic, I just hit them with the heat gun and straighten them out.
Another thing you may want to look into are the oversized RPM wheel bearing carriers. The full set gets a bit pricy, but they will definitely give you more strength in an area that gets pretty beat to hell.
With the full RPM treatment like that, you should be pretty solid.
Sleebus
