Nice Project you have going here. E-Maxxes are so fun....:027: SO many options. Its almost limitless.
Originally Posted by squeeforever
One thing people neglected to mention is that the RPM arms with CVD's is a BIG no-no...The arms will flex and the CVD's will pop out and bend the CVD's. I would go with the RPM Revo carriers and 3.3 sliders...
Couldn't agree more on this one Squee. Bent a few before I learned.
Originally Posted by Josh
I've been debating off-and-on about getting the GorillaMaxx Single Speed. I've been talking with Shawn and he said the transmission should be just fine. I might add on a RRP slipper for a little extra "security". Will have to see what Santa has got in his bag for the E-Maxx :005:
I have a questions concerning the Hardened steel idler gear I've been reading about it and I see you can buy a pair. Should I do that?(buy a pair that is) I haven't really pried open the transmission since I put the FFRC bearings in there.
2 things...
Skip the RRP Slipper. Spend the few extra and get the strobe (
http://www.rc-monster.com/proddetail...per-Kit&cat=40) and the plastic mod1 spur (
http://www.rc-monster.com/proddetail.php?prod=ofn30110) Much better.
If you get the single speed conversion then you only need one steel idler. ;) Even if you dont do the single speed conversion, you will likely only be driving in second gear any way so you could just replace the 2nd gear idler.
