jhautz
jhautz's Avatar
12.19.2006, 02:28 AM
Originally Posted by Cartwheels
Very nice buggy. I'll bet you will get some serious speed out of that setup. I really like your battery holder too! Is that two pieces of angled carbon fiber? I'm assuming that is either 1 inch or 1.5 inch. That is a very good way to do it. I'm converting a Jammin CRT Truggy right now, but I've been hung up on how to mount the lipo packs. The biggest problem is that the packs will hang out past the end of the chassis a little and I have to support it and also anchor the Velcro strap. I might do it the same except with aluminum.
Thanks.:018:
Yea, its 2 pieces of 1x2 carbon fiber angle to make a channel. I find it a little easier to work with using hand tools than aluminum. A dremmel with a fiber cut off wheel and you can pretty much shape it to anything you want. I find it easier than aluminum to work with at home. CA bonds it like iron so joining pieces is pretty easy too.
Just make sure you wear a mask and don't breath the dust. Its not good for you.:020:
to make it...
or break it...
Silent...But Deadly
