jhautz
jhautz's Avatar
12.19.2006, 11:50 AM
Sorry, I wasnt intending to nit pick on that last post. :032:
Yes. That motor will be to small. The motor will be overheating in no time in a vehicle the size and weight of an E-maxx. Look into getting yourself an XL size motor. shoot for a total motor rpm of around 35K rpm when selecting your new motor. That should give you a nice balance of speed and runtime. If you want longer run time choose a motor that will run at a lower rpm.
What I mean choose the battery voltage you will be running, then choose a motor that based on that voltage will result in a max rpm of around 35,000. If you want more speed, choose a wind that will get closer to 40K rpm and for more run time choose a wind that will go closer to 30K rpm.
This is just a rule of thumb to get you in the ballpark. The weight and tire size you are running can effect this, but it a good place to start.
to make it...
or break it...
Silent...But Deadly
