neweuser
neweuser's Avatar
12.22.2006, 12:24 PM
The Feigo would be better cooling people say as it has the attached heat sink. but really, if you want a "cool" system, go with like the 7xl on 4s should be good. Throw a fan on the esc, heat sinked motor, and you should be fine. this would also depend on gearing, what pinion you use, the spur, the pitch of both, your weight, many things.
