12.25.2006, 07:40 PM
Ok, you want the non-Pro. The Pro has the 4.3:1 ratio and the standard has the 3.31:1 ratio. The Pro's come in the truggies for a lower over-all gear ratio so they don't have to run a huge spur. The 4.3:1 will give you to low of a over-all gear ratio. With the 3.31:1 diffs and slipperential, you will already be using a pretty large pinion.
